1989 BMW 525i timing set
CHRIS ORTIZ
Engine Mechanical problem
1989 BMW 525i 6 cyl Two Wheel Drive Automatic
how do i set timing on 1989 525i bmw i set head markings for timing and fly wheel both match but engine turns over but will not start it is getting gas i did this after i changed timing belt (new)?
Feb 5, 2009 at 6:31 AM
DOCHAGERTY
  • 9,606 POSTS
If the marks are correct, then it is not the cam timing. Is there fuel pressure at the rail? You didn't switch the fuel lines did you? If brake cleaner is sprayed in the intake will it start? Check the basics and let me know.
Feb 5, 2009 at 11:12 AM
