1989 BMW 525i Right Low Beam Headlight not working
220,000 MILES • 4 CYL • 2WD • AUTOMATIC
AUTOIGNORANCE
  • 7 POSTS
MY right side low beam headlight is not working.
I replaced the bulb, Checked the fuse no 11 which is OK.
I tried it with a voltmeter, i cannot get voltage upto the fuse no 11. Where else should i look.
Thanks
Aug 27, 2009 at 7:43 PM
DOCHAGERTY
  • 9,606 POSTS
Do you have an electrical diagram? The lamp control module is suspect. It is under hood on the left in the E-box.
Aug 28, 2009 at 2:23 AM
AUTOIGNORANCE
  • 7 POSTS
[quote:177baa4091="Dr. Hagerty"]Do you have an electrical diagram? The lamp control module is suspect. It is under hood on the left in the E-box.[/quote:177baa4091]
Thanks for replying..
I dont have electrical diagram.. If i take the lamp module out... Is there a connectivity test i can run using conventional voltmeter...
Aug 30, 2009 at 4:13 PM
