1989 BMW 525i
169,000 MILES • 6 CYL • 2WD • MANUAL
MICHELLE OLSON
How do I replace the altenator belt in a 1989 BMW535I?
Mar 1, 2009 at 6:46 PM
DOCHAGERTY
  • 9,606 POSTS
Replacement of the drive belts (all the belts) requires removal of the fan and loosening of the adjusters. Install the new belts one at a time starting with the A/C belt. Be sure to tension the belts correctly and do not over tighten the water pump belt, it causes the water pump to wear out.
Mar 7, 2009 at 4:54 AM
