Rear Vibration
RANHAWK
make: BMW
model: 525i
year: 1993
milage: 210,000
engine size: M50
Car has vibration when (after it gets warm) accelarating, particularly after slowing down, coasting for a few seconds, and then accelarating again. Car vibrates or shudders for a second then accelerates normally. Transmission has been replaced and rechecked for problem. No error codes found by mechanic. More general vibration can be felt from the rear between 50-65mph. Tires have been balanced but problem persists.
Any suggestions toward soltuion(s) greatly appreciated. 8)
Jan 14, 2007 at 10:19 AM
WRENCH1
Do you notice any noise coming from the rear at any time? There are several things that can cause a vibration..most of which would also make some noise. The drive shaft u-joints and center bearing(if your model has a 2 piece driveshaft) , the rear wheel bearings, the axle shafts(cv joints), the upper shock mounts, or the shocks themselves. Hope this helps!
Mar 25, 2007 at 10:37 AM
