2003 BMW 525 Engine Light
45,000 MILES • 6 CYL • FWD • AUTOMATIC
FMHANDY
Engine light is on and the code saids the engine is running lean.
Jul 15, 2008 at 3:21 PM
DOCHAGERTY
  • 9,606 POSTS
It is possible there is an intake leak and it might be at the boot from the intake manifold to the air mass sensor. Inspect the small hose that has several bellows in it that serves the idle air control motor that is just to the side of the intake manifold. the part# is 13-54-1-437-191. Let me know if this fixes the problem or if I can help you out with further diagnostics.
Jul 15, 2008 at 4:54 PM
