check engine light goes off and on, idles up and down
Apr 18, 2008 at 2:33 AM
CJONES217
MEMBER
[quote:48808b8850="cjones217"]Shakes or Wobbles problem
1991 BMW 525 6 cyl Two Wheel Drive Automatic 178000 miles
check engine light goes off and on, idles up and down[/quote:48808b8850]
Apr 18, 2008 at 2:35 AM
DOCHAGERTY
✓Experienced Mechanic
Have you scanned the car for faults? This could be an oxygen sensor failing or failed or the idle air control valve might be dirty. Its all guesswork and since the check engine light is on there are stored faults, knowing what these faults are will help me to help you.
