1995 BMW 525i No Engine Power
DANGERCLOSEPGH
I am looking at purchasing a 1995 BMW 525I from a friend that has 99K pampered miles, the car has been properly maintained. It starts and idles fine, there is no visible smoke from the exhaust. When you press the accelerator the engine has no power, when in gear the car barely moves. A mechanic told him it is the head gasket. Is there any test for the head gasket? Should I test the compression in each cylinder? Is this a common problem in the 525I? Any suggestions would be greatly appreciated, it is a beautiful car but I hate to throw money at the wrong problem. Thank you.
Oct 16, 2007 at 2:48 PM
DOCHAGERTY
  • 9,606 POSTS
DON"T BUY THAT CAR
the head may be cracked
Oct 17, 2007 at 1:33 PM
Suggested Repair
Do not buy the car. The expert believes the cylinder head may be cracked.
Conversation Summary
A buyer is considering a maintained 1995 BMW 525i with 99,000 miles that starts and idles normally but has almost no power when accelerated. A mechanic suggested a head gasket. The expert advised against buying the car and said the cylinder head may be cracked.
