1995 BMW 525 Replace Radiator
15,120 MILES • 6 CYL • 2WD • AUTOMATIC
NATEDOGG47
I need instruction on removing a radiator
Jul 17, 2008 at 9:15 AM
DOCHAGERTY
  • 9,606 POSTS
This takes some special tools to get the fan off the water pump (It is left hand thread) and the top clamps for the radiator are a bit tricky to release if you've never done it before, you stick a small screwdriver in the top "notch" and they open up. The rest is quite straightforward. Robert Bentley publishing has a repair manual for the car, you can get one from Amazon.com
Jul 17, 2008 at 5:49 PM
