1995 BMW 525 Leak in the piping @ a joining
ANGELOCATD
Air Conditioning problem
1995 BMW 525 Two Wheel Drive Automatic 192000 miles
Where the a/c lines go into the cab. the connection is leaking @ that point. saw it with the black light and dye. where do I get new seals and is there any major differentences from US cars?
May 5, 2008 at 11:03 AM
MASTERTECHTIM
  • 4,750 POSTS
get the seals from bmw, they should be inexpensive. i find its hard to get aftermarket parts for bmw on this kind of thing. make sure you coat the new seals with pag oil when you install them.
May 5, 2008 at 12:32 PM
DOCHAGERTY
  • 9,606 POSTS
Be aware the leak could be at the brazed fitting and not the o-ring, also, inspect the expansion valve for signs of corrosion, replace if any is present.
May 5, 2008 at 12:57 PM
