1995 BMW 525 Ignition does nothing
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
KABLUND
I Just changed my break pads on a 95 bmw 525i and drove it around the block. The next day I tried to start it and the key ignition does nothing, not even radio or dash board come on. when i have the door open it tells me there is a key in the ignition but still will not do anything. I charged the battery and still nothing.
Sep 21, 2008 at 8:11 AM
DOCHAGERTY
  • 9,606 POSTS
Lets start with checking all the fuses for the front and rear fuse boxes. The rear is under the back seat on the left side. There is also a fusible link inside some shrink tubing that can be found by following the small wire from the positive battery terminal and it is mounted on a piece of Bakelite. Check for these items and repost if this issue needs more diagnosis, I will be standing by.
Sep 21, 2008 at 8:40 AM
DOCHAGERTY
  • 9,606 POSTS
Any luck there?
Dec 16, 2010 at 7:45 PM
