1995 BMW 525 Air Conditioner Stuck ON!
1995 BMW 525
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
MELLIMAN
While replacing the thermostat, radiator and water pump on my 525i, I noticed that the air conditioner is constantly running - even in cold weather. The dash switches are off, of course. I think this has been a long term problem, as the car takes forever to heat up. Where should I begin to look? Is there a fuse or siwtch I could disable to make this problem go away until the summer? Thanks in advance.
Feb 14, 2008 at 3:28 AM
DOCHAGERTY
  • 9,606 POSTS
Disconnect the wire going to the compressor clutch
Mar 10, 2008 at 7:35 PM
