Battery drains. Car needs to be jumped everyday. I recently replaced alternator and battery. Any suggestions?
Thursday, November 20th, 2008 AT 4:28 PM
MECHANIC
HI there,
Get a current draw test done, have an Amp meter placed between Battery Pos (+) and the terminal, (don't try and start the engine) with key out and doors closed check for current dray, if excessive start to pull fuses and fusible links one at a time to isolate the problem circuit, also disconnect the alternator as it may have a faulty diode beck feeding to the battery, start here,
