car cold starts fine runs about ten mins then erridic idle then dies,have to leave key off five mins or so then same deal help please
Jun 7, 2008 at 1:47 PM
DOCHAGERTY
✓Experienced Mechanic
I would initially suspect the coolant temperature sensor as the possible issue here. Is the check engine lamp on?
Jun 8, 2008 at 1:11 AM
FORTUNATO747
MEMBER
possibly go to a salvage yard & get a used electronic ignition module (as new ones are not returnable & quite expensive) see if this cures the problem.
