1997 BMW 523 relays
125,760 MILES • 6 CYL • 2WD • AUTOMATIC
HCLOSEUK
  • 13 POSTS
can you please tell where the relay for the abs system is located
Dec 2, 2008 at 2:42 AM
DAVE H
  • 13,383 POSTS
ABS/ASC Control Module (A52)Behind glove box.
CAUTION:See ANTI-LOCK BRAKE SAFETY PRECAUTIONS article in GENERAL INFORMATION.
Anti-Lock Brake System (ABS) consists of a hydraulic unit with 4 solenoid switching valves, 4 pulse (speed) sensors, an Electronic Control Unit (ECU), relays and wiring harness. See Fig. 1 .
ANTI-LOCK light on the instrument panel comes on when ignition is turned on. ANTI-LOCK light goes out once engine is started, indicating ABS is ready for operation.
ABS activates at speeds greater than 8 MPH. When vehicle speed is greater than 3 MPH, the built-in electronic test monitor will start checking ABS. If a fault is found, warning light will come on. When ABS light is on, ABS is switched off. Vehicle will then convert to conventional braking.
If battery voltage is less than 10.5 volts with ignition on and test speed is exceeded, ABS will remain off until alternator increases voltage output to more than 10.5 volts. ABS warning light will then go out.
Traction control system, called Automatic Stability Control (ASC), controls slip of drive wheels, regardless of road surface conditions. During a control phase, engine torque is reduced by Digital Motor Electronics (DME) system and throttle control system. If this is not sufficient, drive wheel which is spinning too fast is additionally braked using wheel brake in conjunction with a hydraulic actuator.
ASC light in instrument cluster comes on constantly when ignition is switched on as a bulb check. System is switched on after engine start and can be switched off as necessary. ASC light is off when system is switched on. If ASC light is flashing, ASC control is active. If ASC light remains on, system has switched off automatically because of a fault or was switched off manually.
Dec 2, 2008 at 10:00 PM
