2002 BMW 520
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADOULATOS
Hi
I had Transmission oil leaking out of the inspection hole of my automatic gearbox. Is this a seal in the box that is finished or does it just need an atf oil change. Please help.
Thank you
Sep 24, 2010 at 6:37 AM
DOCHAGERTY
  • 9,606 POSTS
What inspection hole?
Sep 29, 2010 at 2:58 AM
ADOULATOS
Hi thanks for your reply
There is a hole at the bottom of the gearbox. its between the torch converter and the gearbox itself. The ransmission oil just started pouring out. Im sure its either the torch converter seal or bush. How do i change this...Unless it just needs an ATF change.
please help
Sep 29, 2010 at 8:33 AM
DOCHAGERTY
  • 9,606 POSTS
Thanks for the clarity. A leak of that magnitude will require removal of the transmission to inspect for possible damage and to see where the issue really is located. It could be most anything, a seal failure or perhaps the torque converter itself, I have seen them leak from a crack in the housing.
Sep 30, 2010 at 1:56 AM
