2000 BMW 520 Sometimes struggles to accelerate
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADRIAN_HOGBEN
I have recently bought a 2000 Auto BMW 520 Touring with approx 95k mileage. I bought a CD Player through Halfords who fitted it and removed the BMW Business player. A week or so later, the Air Con wouldn't switch off even when the keys were not in the ignition eventually resulting in flattening the battery. After jumping the car with jump leads, I somehow managed to get the Air Con off but every now and again it would come back on and turn off at will; once more flattened the battery. I jump started the car again and that was the last time I had any problems with the air con but I think the battery is now so damaged that if I leave the radio or something on for anything more than 10 mins without the engine being on, the battery dies and needs to be jumped again. I have now learned my lesson and don't leave anything on without the engine being on and I intend to get a new battery in the next few weeks. However, my car has now developed a new problem which I am hoping is linked to having a duff battery. Every now and again (but becoming more regular), when I start the car, it can initially really struggle to accelerate for about 2-3mins but after that it runs fine? Will this be rectified if I buy a new battery or is it likely to be another problem?
Apr 16, 2009 at 8:51 AM
DOCHAGERTY
  • 9,606 POSTS
I dont think all your problems are going to be solved with the purchase/installation of a new battery even though you need one. The A/C issue may be due to the final stage for the fan is draining the battery and it will continue to do so until replaced. Get that issue resolved and then we can see if the replacement of the battery is all that it needs for the engine to run correctly again. And yes, a dying battery can cause these issues due to the fact that the newer BMW cars are very dependent on a strong battery and charging system to perform as designed. Keep in touch and let us know.
Apr 16, 2009 at 9:31 AM
