I would like to receive an advice before go to mechanic.
my car does'nt start, batery is good I checked, there is power, but when I put the key inside and turn to start. Nothing, no start, no noise, nothing.
Tuesday, September 28th, 2010 AT 8:25 AM
MECHANIC
No crank at all/nothing/nada when key is engage to starting position
Could be the starter, starter relay, clutch switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
SPONSORED LINKS
Tuesday, September 28th, 2010 AT 10:08 PM
DOCHAGERTY
MECHANIC
The drive away protection (called EWS) is suspect. It might require realignment.
