1992 BMW 520 hesitation
1992 BMW 520
JSDEBOLT
Engine Performance problem
1992 BMW 520 6 cyl Two Wheel Drive Manual
I drove thru a deep puddle and then the next time I drove it it had a real bad hesitation/ misfire and has had it for 2 months now
no engine light on
Jul 18, 2008 at 3:25 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
Check ingnition components they may have gotten wet also see if there is water in air cleaner.
Jul 18, 2008 at 3:36 PM
KLSHIEL
  • 163 POSTS
often when you get bad ignition wires wet it will run badly. Water my have gotten into the electrical system somewhere, but if that is all it is it should get better the next time you get it real hot because the water will evaporate.
Jul 18, 2008 at 3:39 PM
DOCHAGERTY
  • 9,603 POSTS
Is there a check engine light on?
Jul 18, 2008 at 11:17 PM
JSDEBOLT
[quote:5fff0f03b9="Dr. Hagerty"]Is there a check engine light on?[/quote:5fff0f03b9]
no my engine light is not
Jul 18, 2008 at 11:31 PM
DOCHAGERTY
  • 9,603 POSTS
The secondary air injection intake was placed in an unfortunate location on those models, when they encountered deep water there was a possibility of water going into the engine. There are no spark plug "wires" as these engines utilize coil over type ignition and it is once again possible to have a coil failure (or coils) The electronic sophistication of the newer BMW cars is such that they require diagnostic equipment that is used at the dealership and some of the higher end independent repair facilities, you may have to seek out one of them in your neighborhood in order to resolve the issue(s).
Jul 19, 2008 at 6:49 AM
