2002 BMW 335
MCDOHANEY
  • 5 POSTS
2002 BMW 335
The speedo on my 2002 325i just stopped working. Any idea what is might be?
Dec 21, 2008 at 8:57 PM
DOCHAGERTY
  • 9,606 POSTS
The road speed signal comes from the DSC control unit. Is there a warning light on for DSC in the display?
Dec 22, 2008 at 7:36 AM
MCDOHANEY
  • 5 POSTS
Yes the dsc light has been on previously but then it seems to go off later.
The other thing that has happened is that the signal are not cancelling now when the lever is activated to signal a left or right turn.
Mar 30, 2009 at 5:47 AM
DOCHAGERTY
  • 9,606 POSTS
Send the last 7 of the VIN and I can steer you to the right part numbers.
Mar 30, 2009 at 7:52 AM
MCDOHANEY
  • 5 POSTS
[quote:8f225487bb="Dr. Hagerty"]Send the last 7 of the VIN and I can steer you to the right part numbers.[/quote:8f225487bb]
The last 7 digits ar:
KL55243
I am assuming both the speedo and the signal problem are related to the dsc control unit as each seems to be happening intermitantly but not at the same time. When the speedo works the signals do not cancel but when the signals cancel the speedo does ot work.
Thanks for your help.
Apr 16, 2009 at 1:48 AM
DOCHAGERTY
  • 9,606 POSTS
34-51-6-756-289 is the part # for the repair kit to the DSC. It will need to be coded to the car and the dealer can do this or an independent BMW repair shop with the right equipment. Go to Realoem.com for price and availability.
Apr 16, 2009 at 6:25 AM
