torque converter/ computer problem
FLAMINGONEAL
2002 BMW 330i has 89,000 miles. I took the car in for service-oil change, brake flush & fluid. Three days later the Check Engine light illuminated. Took it back to the dealer and they read the following codes: P 0740-Torque converter clutch circuit malfunction, P 0741-Torque converter clutch circuit performance or Stuck Off. and P2762. Other numbers: code 048 30 converter lock up clutch pre-tsb 21-03-06 milage 77108. I also had the module for general faults replaced on 4/5/06. The car rides well and I have seen no change in gas milage. The dealer recommends a new torque converter. I think there might be one or more bad sensors or a wiring problem or another computer problem. What can be done to verify the computer is telling the truth?
Oct 3, 2007 at 3:07 PM
DOCHAGERTY
  • 9,606 POSTS
to interpret the information takes knowing all the facts
and some informed guess work.
after working at the dealer level for many years, I can tell you no body knows it all, not even the dealer.
it is possible you need a converter but I can not recommend replacement with the information available.
you may wish to get a second opinion.
Oct 29, 2007 at 3:55 AM
