My car has a rough idle and service engine light is on. How can I fix it?
Nov 24, 2007 at 6:54 AM
Suspect failing ignition coils. Contact a BMW dealer about voluntary emission bulletin 12-13-05 and confirm whether coil replacement is covered before authorizing work. A short drive to the shop is unlikely to cause damage if the car is safe to drive; otherwise have it towed.
The owner of a BMW 330 reported a rough idle and service engine light after the car sat for two weeks, with only regular oil changes noted. Another owner of a 2005 325i reported a sudden similar problem with reduced power. The expert suspected ignition coils, cited BMW bulletin 12-13-05, and advised calling a dealer because coverage may not be free. Short driving was considered acceptable if safe; otherwise the car should be towed.
