2006 BMW 330 reverse light
BUTCH MILLER
Electrical problem
2006 BMW 330 6 cyl All Wheel Drive Automatic
no reverse lights. bulbs good no voltage to lamp. checked fuse 36,41,52,52 to footwell module all good. need lacation of reverse switch, looks like trans, looking at switch. where do i go from here.
I would be glad to donate after problem is fixed.
thanks butch
Feb 20, 2010 at 6:55 AM
DOCHAGERTY
  • 9,606 POSTS
The reverse light is managed by the shift selection switch. I will get a wiring diagram when work resumes on Monday.
Feb 21, 2010 at 1:28 AM
BUTCH MILLER
dr hagerty i donated $10. please send wiring diagram. thanks butch
Feb 22, 2010 at 3:25 AM
BUTCH MILLER
I have donated and am waiting for Dr Haggerty to send a wiring diagram for the car. So far he tolld me it is controlled by a shift selection switch. I was looking for a reverse light switch which I can purchase for $8.00 . I knew this befor I asked a question on the forum. I am starting to wonder if I have been scammed? Butch
Feb 24, 2010 at 1:32 AM
BUTCH MILLER
up on lift can see no switch gear position or reverse light. Where is it and how much must i take off to get to it? Can you tell me how to get to it?
Butch
Feb 24, 2010 at 4:06 AM
DOCHAGERTY
  • 9,606 POSTS
I would suspect the switch too, except that the signal for an automtic is sent through the communication bus, please know that the foot well module has it's share of issues as well. The complexity of the car usually has me reaching for the scan tool and in this case the "can" signal may or may not be telling the foot well module to turn on the lights. I recommend seeking out someone with the appropriate equipment to diagnose your issue, trial and error can often lead to unwelcomed issues.
Feb 24, 2010 at 4:57 AM
