2002 BMW 330 Internal fan continues to run when ignition is
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
MATT GARRATT
Hi - I have a BMW 330 sport, 2002 and when I turn the ignition off the internal fan continues to blow and as a result it flattened the battery last week. If I remove the blower 40amp fuse this turns the fan off but I would like to get the problem sorted properly. Can anyone assist me please or know if this is a common fault?
With thanks
Matt
Aug 3, 2010 at 11:34 PM
DOCHAGERTY
  • 9,606 POSTS
Yes Matt, it is a common fault, the final stage unit that controls the fan is a potted semi-conductor device that fails all the time.
Aug 4, 2010 at 1:44 AM
