2002 BMW 330 camshaft positioning sensor
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
MELISSA330I
If you replace the camshaft positioning sensor why does it still shoot a code and the ck engine light stay on
PO369 camshaft positioning sensor circuit B intermitten Bank One
Sep 9, 2010 at 7:17 AM
DOCHAGERTY
  • 9,606 POSTS
Replacement of the sensor alone will not send the code away, you must reset the fault. What scan tool are you using? It should have the ability to clear faults. Have you replace the correct sensor?
Sep 9, 2010 at 4:20 PM
