2001 BMW 330 variable induction intake valve
98,000 MILES • 6 CYL • AWD • AUTOMATIC
RONS429CJ
I have removed the 2 torx bolts. The valve will come out a little but is binding. Should it just pull out or is something else holding it?
Nov 28, 2009 at 7:16 AM
DOCHAGERTY
  • 9,606 POSTS
A bit of force should do it mate, it is supposed to come right out, unless it is broken. If so you will need to use a bit more force, and then be sure you get all the pieces out.
Dec 8, 2009 at 3:45 AM
