2001 BMW 330 rough engine no idle
110,000 MILES • 6 CYL • 2WD • MANUAL
LGLAVAN
just had fuel pump replaced. When fuel gets to a 1/4 tank idle gets rough, sometime wont even idle. Fill it up and it runs fine.
Lou
Nov 28, 2008 at 2:55 AM
DOCHAGERTY
  • 9,606 POSTS
It very well might require removal of the fuel pump to see what went wrong with the installation. Also check to see if the siphon jet was disturbed, it is what transfers fuel from the left side of the tank so that the pump can pick it up.
Nov 28, 2008 at 5:11 PM
