2001 BMW 330 Hot Air from one vent and cold from the other
2001 BMW 330
105,000 MILES • 6 CYL • AWD • AUTOMATIC
LDEWEIL
A week ago, I had lost all radiator coolant after a blocked thermostat overheated the system. The expansion tank and "water pipe" needed to be replaced at total cost of $2500.
A few days later, I turned on the AC for the first time. I get cold air out of the front panel and hot air out of the defroster vent.
What is strange, is that if I close the defroster vent, the front vent changes to lukewarm air. Also, changing the temp gauge to hot does not change the temp of the air.
Do you think the coolant loss and the air condition vent malfunction are related? The AC worked fine before the repair but was not used since last summer.
Thanks
Apr 23, 2008 at 10:36 AM
DOCHAGERTY
  • 9,606 POSTS
You need to have the car scanned for faults and repost to me. It seems like you spent a lot of $ for a T-stat and a water pipe.
Apr 23, 2008 at 2:15 PM
