2001 BMW 330 cracked head
2001 BMW 330
EDDIETBOURQUE
Engine Mechanical problem
2001 BMW 330 Two Wheel Drive Automatic 173000 miles
I have a 2001 330I and just recently cracked the head. The mechanic I took it to said that it would be best to replace the engine. I can not afford that right now. What reasons would he have for not replacing the head only. Unfortunatly I am not that savy with car mechanics.
Thanks
Jan 27, 2009 at 1:36 AM
DOCHAGERTY
  • 9,606 POSTS
Because the block is aluminum, and when the cylinder head is bolted on, the torque required can and often does pull the threads out of the block. I have a source for an engine if you require.
Jan 27, 2009 at 2:59 AM
