1999 BMW 328 starter
1999 BMW 328
123,456 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIAM OLIVER
  • 25 POSTS
any idea how replace or easy way to remove the starter thanks for any help
Apr 10, 2008 at 11:20 AM
DOCHAGERTY
  • 9,606 POSTS
The starter is accessed from under the car. The transmission needs to be lowered to get to the starter bolts. It can then be removed from under the manifold. This is not terribly difficult, but if you don,t have access to a vehicle lift I would seek out someone that does, It makes it so much easier. If you need a manual for the car, don't buy anything but the Bentley manual, it is available through Amazon.com
Apr 11, 2008 at 7:39 AM
