1999 BMW 328 Replace brake light bulbs - 1999 BMW 328i
132,000 MILES • 6 CYL • 2WD • AUTOMATIC
FALVAREZ
My son's rear brake lights(left and right, not the center one) are not working. I checked the fuse and it is ok. I went to check the bulbs by looking in the turnk area but cannot figure out how to get at the bulbs. There is a big black plastic cover that I cannot seem to take off. Any suggestions?
Frank
Jun 13, 2009 at 11:37 AM
DOCHAGERTY
  • 9,606 POSTS
Is it an E-36 or an E-46? The plastic cover has either a snap or a quick turn, I cant tell from cyberspace. Also inspect for possible wiring damage at the trunk lid wiring feed harness, it is a source for issues in lighting and trunk access.
Jun 13, 2009 at 4:47 PM
FALVAREZ
Dr. Hagerty,
Thank you Dr. Hagerty for answering me so quickly. It is an E46. The only thing I noticed are some small and 2 large black snaps similar to what BMW uses to secure the liner under the hood. Not sure if that helps any. I tried removing a few of them but the plastic cover did not appear to become loose.
Frank
Jun 13, 2009 at 11:56 PM
