1999 BMW 328 Mode Selection Switch
72,000 MILES • 6 CYL • 2WD • AUTOMATIC
THESICILIANSPECIAL
The Mode Selection Button located on the Turn Signal Lever does not change the Dash Display. Currently the Outside Tempurature is displayed and can be changed from C to F. However pressing the Button in Key positions one or two does not change the display. What could possibly be the root cause of the non working switch.
FYI: In key position 0 and pressing the left instrument button Time is displayed.
Jul 11, 2008 at 6:18 PM
DOCHAGERTY
  • 9,606 POSTS
There was a model change in 1999 and I will require the last seven characters of the vehicle identification number to be sure I know what the issue might be, please repost with the requested data.
Jul 12, 2008 at 12:09 AM
THESICILIANSPECIAL
the last seven numbers of the VIN are
FR08071
Jul 12, 2008 at 3:10 AM
DOCHAGERTY
  • 9,606 POSTS
Thank you for the response. The E-46 body style uses several CAN-BUS systems to convey information, the instrument cluster utilizes what is called a K-Bus and this seems like a low voltage condition on the K-Bus. This I have also seen as an internal fault in the instrument cluster.
https://images.2carpros.com/forum/automotive_pictures/87023_STFU_File_7.jpg
https://images.2carpros.com/forum/automotive_pictures/87023_STFU_File0001_3.jpg
https://images.2carpros.com/forum/automotive_pictures/87023_STFU_File0002_2.jpg
Jul 12, 2008 at 5:50 AM
