Engine Performance problem
1999 BMW 328 6 cyl Two Wheel Drive Automatic
We have the equipment to hook up and pull codes. We also have AllData. The problem is once we get the codes we need to know more information to diagnosis and repair. We will gladly donate but of corse want to make sure this is official. Have had trouble in past w other sites. The manufacture codes are 240 243 239 241 228 and 151. If you could kindly help we will be bookmarking this and using you often. If you could kindly respond back asap that would be much appreciated.
Oct 8, 2009 at 4:08 AM
