1998 BMW 328 Shaking and steering problem
1998 BMW 328
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
GLSCWS
I have been having problems with shaking in my steering wheel when braking. Today, in additon to the shaking, I noticed a light grinding noise when turning mostly to the left (although it happened once to the right as well). Any help would be appreciated. Thank you.
Aug 9, 2009 at 11:21 AM
  • 31,937 POSTS
Hi there,
Have the front brakes inspected for wear, you may almost be metal to metal, the vibration under braking is normally due to brake rotor warping.
Mark (mhpautos)
Aug 9, 2009 at 5:54 PM
DOCHAGERTY
  • 9,606 POSTS
It may also be a symptom of worn lower control arm brackets.
Aug 10, 2009 at 7:26 AM
