1998 BMW 328 Engine Fan
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHOATJOR
The engine fan on the inside of the radiator wobbles whenever the motor runs, making a loud gurgling noise. Is there a bolt to tighten up the fan, or is it a bigger problem originating inside the water pump.
Oct 5, 2008 at 5:28 AM
DOCHAGERTY
  • 9,606 POSTS
Seems like you got a problem with the pump, I would consider replacement of the pump and an inspection of all the cooling system components ♥
Oct 5, 2008 at 5:59 AM
