1998 BMW 328 Check Engine Light
1998 BMW 328
RYAN82586
  • 11 POSTS
Engine Mechanical problem
1998 BMW 328 6 cyl Two Wheel Drive Manual 160k miles
My check engine light has recently come on. I tried erasing the stored code by pulling the positive on my battery for a few seconds. Check engine light remained on directly at start up. I was wondering if there is a way to get the codes from the Data Link Connector without having a Peake or OBD or other diagnostic tool. I have a suspision that this is possible, because unknown by many, I know a way of simply reseting the oil service and inspection service lights without having a tool at all. Just some common things I could find around the house.
There must be a way. I'm thinking that if you ground a certain terminal (or several) in the data link connector and then turn the ignition to position 2 that the check engine light will blink a series of codes with pauses, short blinks, and long blinks or something to that affect. What are your thoughts?
Thanks!
Mar 4, 2008 at 9:43 PM
RYAN82586
  • 11 POSTS
I probably should have mentioned that my car has been sucking down more coolant then usual.
Mar 4, 2008 at 9:45 PM
