1998 BMW 328
TOMASW
  • 1998 BMW 328
Engine Cooling problem
1998 BMW 328 6 cyl Two Wheel Drive Automatic 141K miles
Hi there,
I am having problems with my car cooling system.
I have filled up the cooling bottle a few times but it goes all the way down in a few hours.
I have taken it to two mecanics ( not bmw dealer ) that work or have worked with BMW, and none of them could tell me where is the problem.
I thought there was a lick from a hose or the bottle itself, but so far could not see it. The temperature gage is fine, so the car is not over-heating.
I have tighten the bottle lid thinking that the problem could be because a loose lid. But did not work.
Thank you very much in advance for your help,
Tomas
Friday, September 17th, 2010 AT 12:09 PM
WRENCHTECH
  • 20,761 POSTS
The cooling system has to be pressure tested and if the problem is anything but a bad cap, the problem will show up.
Friday, September 17th, 2010 AT 12:33 PM
DOCHAGERTY
  • 9,601 POSTS
There is a possibility of the cylinder head casting having a crack that only opens on the cool down or when it is hot. Sorry, I dont make the news, I just report it.
Friday, September 17th, 2010 AT 8:21 PM
