1997 BMW 328 thermostat
1997 BMW 328
SHAVE242
Engine Mechanical problem
1997 BMW 328 6 cyl Two Wheel Drive Automatic
How do I replace the thermostat? pictures would help
Jan 20, 2009 at 4:08 AM
DOCHAGERTY
  • 9,606 POSTS
https://images.2carpros.com/forum/automotive_pictures/87023_STFU_File0005_2.jpg
Here is an exploded view of the T-stat and water pump. The fan and the shroud need to be removed first, then the bolts can be accessed. The fan can be removed with a thin 36mm open end wrench and it is a left hand thread. The plastic buttons that hold the shroud often break and I usually replace them with plastic zip ties. I recommend replacement of the water pump if it's age is unknown and for preventive maintenance.
Jan 20, 2009 at 4:53 AM
