1997 BMW 328 Sligh bend in strut tower causing camber to be
1997 BMW 328
118,000 MILES • 6 CYL • 2WD • MANUAL
MATTOD
Hello - I recently had my wheels aligned and the service technician said that the strut towers have a slight bend and that is making the camber 1/2 of a degree off on the left and 2/10 of a degree on the right. Should I be concerned with camber that is out by this much? Is this something that will cause uneven tire wear?
Jul 30, 2008 at 7:02 AM
DOCHAGERTY
  • 9,606 POSTS
It can cause uneven tire wear and the possibility of a bent strut as well as the deformed strut tower can be corrected and I would suggest getting the shop that told you about the strut tower issue to quote for the repair work and let us know the outcome.
Jul 30, 2008 at 1:39 PM
