1997 BMW 328 cr won't turn off even with key removed
1997 BMW 328
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
JASONBOSS
my car won't turn off even when Iremove the key - i have to disconnect the battery
Jul 1, 2008 at 11:20 AM
This is what you called dieseling/run on -readjust the idle speed don't work clean the throttle plate could be sticking open and reset the idle again
Jul 1, 2008 at 11:40 AM
DOCHAGERTY
  • 9,606 POSTS
The ignition lock assembly is broken and will possible need inspection/replacement. Part# 32-32-1-093-265. This requires special tools and skills, not a job for beginners.
Jul 1, 2008 at 12:59 PM
