1997 BMW 328 Blower motor made noise and wont come on
13,500 MILES • 6 CYL • 2WD • AUTOMATIC
97 BMW 328
My AC has suddenly stopped. At first the blower motor made a slight grinding sound and then suddely quit. Could you tell me where in the car the blower motor is located and where I can find a reasonably priced replacement? Thank you
Jun 17, 2008 at 6:06 AM
DOCHAGERTY
  • 9,606 POSTS
The blower motor is located behind the fire wall, directly under the windshield. There are several online suppliers for BMW parts. Try Realoem.com. Also you may wish to consider replacement of the fan motors final stage(the module that controls the fan speed) if the new fan motor does not get rid of the problem. The reason I recommend replacement of both is that I have seen the final stage cause issues with motor noise. Repost if you require assistance with the installation.
Jun 17, 2008 at 6:31 AM
