1996 BMW 328 FAILURE EMISSION
ISAACX55
  • 5 POSTS
Engine Mechanical problem
1996 BMW 328 6 cyl Two Wheel Drive Manual
my BMW failure the emission test and the computer shows the PO170 AND PO173 codes. they told me that has a rich mixture and unburned fuel! what i can do to fix it? i think is a some sensor because it dont has a vacum liks and the car runs perfect!
Jul 14, 2009 at 1:34 PM
  • 75,988 POSTS
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode
Jul 14, 2009 at 10:15 PM
ISAACX55
  • 5 POSTS
i changed the senssors, the o2, and the fuel pressure regulator and i still have the same problem. What suggestions or what other solutions are there?
Jul 19, 2009 at 11:05 AM
  • 75,988 POSTS
How about the rest of the stuffs do they checked out also??
Jul 19, 2009 at 12:57 PM
ISAACX55
  • 5 POSTS
does the coolant really hav to do anything wit my problem ?? my car tells me to check the levels of the coolant but the levels are all fine or is it possible that its the cars computer and the code was PO600
Jul 20, 2009 at 7:51 AM
  • 75,988 POSTS
P0600
This code indicates that the computer PCM has lost of serial communication link, the PCM will need to be replaced to repair this problem.
Jul 20, 2009 at 7:56 AM
ISAACX55
  • 5 POSTS
what is PCM??
Jul 20, 2009 at 8:02 AM
  • 75,988 POSTS
The computer-PCM (Powertrain Control Module)
Jul 20, 2009 at 8:04 AM
ISAACX55
  • 5 POSTS
I reprogramed the computer, the specialist told me to check the basics first and go from there, like check spark-plugs,coils,any vacum leaks which i alredy did and he told me that the oxygen sensors are reading to rich, besides those two codes two new other codes appeared P1188 and P1189 sometimes it detects the cylinder codes as a problem but it goes off right awway sometimes two codes and other 3 or more what do you recomend doing from here?
Jul 23, 2009 at 7:55 AM
