1996 BMW 328 check engine light on
72,000 MILES • 6 CYL • 2WD • AUTOMATIC
ESIGO
All I want to know is how to clear check engine light out, will take in to be service if light comes on again.
Jan 22, 2010 at 10:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating!
You will need to use an OBD-II diagnostic scanner to delete the trouble codes stored , which will in turn remove the check engine lamp. Most auto part stores will do this for free if you ask them to. Before having this done, ask the auto part store associate to retrieve the trouble code(s) for you as well. Post the code(s) here and I can assist you with the problem and most likely save you a lot of time and money instead of taking to a dealer.
Jan 22, 2010 at 12:45 PM
