2002 BMW 325 Whining Steering
PROVO33
When I turn the steering wheel the car is making a whining noise checked power steering fluid level it is good, there is some condesation on the top of the power steering holding tank. Do I have a bad pump or is there a leak somewhere.
Mar 21, 2007 at 2:13 PM
MERLIN2021
  • 17,250 POSTS
If there was a leak, it would be impossible to miss...look under the car for oily spots. You may be able to add a little conditioner to the pump but...sucess not a guarantee.
Apr 2, 2007 at 8:20 AM
Suggested Repair
Inspect under the car for oily power-steering fluid spots. A leak would usually be obvious. If none is found, a pump conditioner may be tried, though success is not guaranteed.
Conversation Summary
The owner of a 2002 BMW 325 reports a whining noise when turning the steering wheel. The power steering fluid level is good, with some condensation on the reservoir, and the owner asks whether the pump is bad or there is a leak. The expert says a leak would be hard to miss and advises looking under the car for oily spots. A little conditioner may be added to the pump, but success is not guaranteed.
