knock from rear end
STANJ
2002 325i sedan
very strange situation....
sounded like I had something rolling around in the trunk, crashing against the walls. then, I thought it may be backfire in the muffler. Stood outside with engine running, could not hear anything. but definitely noise when sitting inside. Doesn't make a difference if the car is standing still or moving...same noise. Also, this only happens intermittently. Sometimes, a couple of days passes without anything. Then, when you least expect it...crash. Any ideas...exhaust, drivetrain, fuel sytem?? No engine misfire. At least, not yet. thanks in advance for any suggestions.
Mar 17, 2006 at 11:52 AM
BAMADAVE
  • 8 POSTS
Check and see if your electric antenna is coming up. If not, you could be hearing it. Open the tunk while it's happening to isolate the sound.
Mar 29, 2006 at 10:33 PM
