I have a check engine light on for a 1994 325i 6 cyl and dont want to take to dealer. Any suggestions on where to get a scanner for this model?
Nov 5, 2007 at 9:58 PM
✓ASE Certified Mechanic
Hi there,
Scanners are so very expensive, I have a snap on scanner and you would shudder at the price, i do scans for customers all the time and charge a flat rate for the service. I would ring around any large independent workshop and ask if they can do a scan for you, i charge $50. for a scan but remember that this is a $25,000 investment so be prepared to pay for the privilege.
Mark (mhpautos)
Nov 6, 2007 at 2:53 AM
DOCHAGERTY
inexpensive code scanners can be purchased at parts supply houses. Pep boys or kragen or whatever regional parts supplier is in your community or on the internet. depending on the mileage of the car, my guess is the oxygen sensor may be the cause and a scanner will tell you for sure.
Nov 6, 2007 at 10:42 AM
Hi there,
Here in Aust i don't think that i have ever seen a cheap scanner for sale in a auto spare parts shop ( not including the provisional range) so if you can get generic cheap scanners over there, that's what i would be doing as well, but make sure that it will read all the codes systems that you need.
Mark (mhpautos)
Nov 6, 2007 at 6:16 PM
JRZJR
MEMBER
Thank you for your messages, the problem I am having is finding a scanner for the year of my car. For whatever reason most scanners I have inquired on the internet or at NAPA do not apply to models later than 1996. And you are right about the O2 Sensor I have replaced it but I continue to get fouling in the exhaust causing a similar emissions problem to exist which is why I am so reluctant to continue to pay a mechanic for this information but your probably right, thats the next step.
jz
Nov 7, 2007 at 8:27 AM
