I have condesation in my front turn signals is there anyway to fix this w/out replacing
Mar 21, 2007 at 2:21 PM
MIKE H R
MEMBER
you can try taking the bulb out, using a hair dryer on low blow warm air into the socket where the bulb came out. DO NOT USE HIGH HEAT the lens and case are made of plastic. the moisture in the lens will evapotate, this does take some time to get the moisture out but it does work.
Mar 22, 2007 at 1:24 AM
