2002 BMW 325 AC Cuts Out When Hot
BUSTERCAT
I have a 2002 325 IT.
Lately when the car is hot inside and the A/C is at full tilt to get the car cool (the a/c set to Auto / Temp 72) it blows ice cold as usual for about 3 mins, then completely shuts down for about 30-40 seconds and then comes back on. This will continue until the car is cold enough and the fan isn't blowing at full speed.
I have tried to manually use the fan at this time, by switching from Auto and pushing the fan button, but this does not help. I just have to wait for the cycle and the a/c will return.
Any ideas? Really more annoying than anything else, I am just afraid it is a symptom of a larger issue.
Thanks, Buster
Jun 12, 2007 at 1:08 AM
DOCHAGERTY
  • 9,606 POSTS
sounds as if the fan final stage is starting to fail
Jul 23, 2007 at 11:04 PM
BUSTERCAT
Yes, I replaced the final stage about a month ago, WHAT A B**** it was to fit my hand in there to remove it. Now everything is back to normal.
Thanks,
Jul 24, 2007 at 8:27 AM
DOCHAGERTY
  • 9,606 POSTS
yes,it is related to a female dog.let me know if anything else pops up. DR.Hagerty
Jul 24, 2007 at 8:47 AM
Suggested Repair
Replace the blower fan final stage. The owner confirmed that replacing it restored normal A/C operation.
Conversation Summary
A 2002 BMW 325IT blew ice-cold air for a few minutes when the cabin was hot, then the A/C shut off for 30-40 seconds and returned, repeating until the cabin cooled and fan speed dropped. Manual fan control did not stop the cycling. The expert suspected a failing fan final stage. The owner had already replaced it and reported that the A/C then worked normally.
