325i 87 Model , Overdrive gear is not working probebly
1932 BMW 325
MAJD2002
hi sir ,
i have 325i coupe 1987 model with aotumtic gear transmission , recently i face problem that the car when u drive over 80KM it should go to overdrive mode , but it will start moving between gear4 and overdrive without i do anything even if i'm not pressing on the accelerator. and on the last days the over drive stocked and it will not go to that mode even if i accelerate .
Aug 23, 2007 at 3:31 AM
DOCHAGERTY
  • 9,606 POSTS
possibly an internal fault in the valve body. May require removal of pan to further inspect.
Aug 23, 2007 at 6:48 AM
MAJD2002
[quote:dac37499e0="Dr. Hagerty"]possibly an internal fault in the valve body. May require removal of pan to further inspect.[/quote:dac37499e0]
Thank you sir for relting my Question , i froget to include in my msge that i had been replace the valveody , the gear , the comp. of the ger ,the comp. of the engine and the TPS without an advantage. can you please advise.
Thanks alot :D
Aug 26, 2007 at 9:56 PM
