2006 BMW 325 p1449
72,000 MILES • 6 CYL • AWD • MANUAL
ROBERTTRIGARRETT
I have a code p1449 evap check solenoid circuit malfunction. BMW says not a real big problem but wants $950 to fix it. What can I do myself.
Jan 29, 2010 at 12:56 AM
DOCHAGERTY
  • 9,606 POSTS
The P code is ambiguous as it relates to the issue at hand, what is the problem? Is it replacement of a part?
https://www.2carpros.com/makes/bmw/325
Jan 30, 2010 at 11:07 AM
ROBERTTRIGARRETT
Thanks for the exploited view. With further investigation it appears I need to replace the dmtl pump. That doest look to bad. And not to expensive for a do it yourself project
Jan 30, 2010 at 11:33 AM
DOCHAGERTY
  • 9,606 POSTS
And then restting the fault, a generic OBDII reader should do it mate, cheers.
Feb 1, 2010 at 3:22 AM
