Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
BMW
325
Engine
Piston
Rod
Bearing
2005 BMW 325 Torque sequence for rod and main bearings on t
2005 BMW 325
154,231 MILES • 4 CYL • 2WD • AUTOMATIC
RODNEY ANDERSON
MEMBER
1 POST
Looking for the correct procedure and torque values for the rod and main bearings on the 2.5 engine?
Sep 23, 2010 at 6:14 AM
DOCHAGERTY
Experienced Mechanic
Replace and torque con rod bolts to 20nm and then 70 degrees of angle. Main caps are 13nm and the 45 degrees
Sep 29, 2010 at 3:22 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
